miyagis720 Posted May 5, 2014 Report Share Posted May 5, 2014 The tranny went out in my 720 i recently picked up a 5speed out of an 88 d21 will it bolt up directly to my z24 and drive shaft Quote Link to comment
datzenmike Posted May 6, 2014 Report Share Posted May 6, 2014 The '88 D21 used a Z24i and a VG30 V6 engine. As long as it's from a 4 cylinder it will bolt to your Z24. However it is a different design transmission and while the driveshaft spline is the same, the over all transmission length is likely slightly shorter. Also look on the engine tag, right inner fender under the hood hinge. '88 and '89 D21s did have a 4 speed option that could be mistaken for a 5 speed. The engine tag should say FS5W71C and NOT F4W71C 1 Quote Link to comment
miyagis720 Posted May 6, 2014 Author Report Share Posted May 6, 2014 I know it was from a 4 cylinder extra cab 5 speed i believe32.5 inches which is i think the same as mine Quote Link to comment
miyagis720 Posted May 6, 2014 Author Report Share Posted May 6, 2014 I guess i should have started with year so either way i have a 1985 nissan 720 extended cab 2 wheel drive with a nap z 2.4 liter Quote Link to comment
