jaredperry Posted October 22, 2013 Report Share Posted October 22, 2013 I searched and wasn't able to find... Maybe I just suck at looking, but are there any good threads on how to install rear subframe bushings? Zee big ones? Thanks! Quote Link to comment
jaredperry Posted October 23, 2013 Author Report Share Posted October 23, 2013 That was a lot easier than I thought it would be... -Put car on rear jack stands -Remove wheels -Remove rear exhaust section -Loosen rear mustache bar, but do not remove the nuts -Remove rear section of the drive shaft from the Diff -Remove the nuts holding the rear subframe. Everythigng should loosen/drop slowly once lightly shaken -Use a screw driver and pry out the halved bushings -Clean up the debris and prepare for bushing installation Reverse the dissasembly Entire bushing install took me about 1.5 Hrs once I figure out what I was doing 1 Quote Link to comment
