Rear subframe bushings
jaredperry
  • Replies 1
That was a lot easier than I thought it would be...
-Put car on rear jack stands
-Remove wheels
-Remove rear exhaust section
-Loosen rear mustache bar, but do not remove the nuts
-Remove rear section of the drive shaft from the Diff
-Remove the nuts holding the rear subframe.
Everythigng should loosen/drop slowly once lightly shaken
-Use a screw driver and pry out the halved bushings
-Clean up the debris and prepare for bushing installation
Reverse the dissasembly
Entire bushing install took me about 1.5 Hrs once I figure out what I was doing
