DatsunMotorSports Posted August 12, 2013 Report Share Posted August 12, 2013 Just FYI for you local Ratsuners 1980 200sx, someone already made off with the rear end(which is what I was after) Auto trans LZ engine(didnt check but probably the 2.2L) 1977 A10 L20B engine missing cam, but w58 head on it still) 1970 521 4x4 conversion dog leg 5spd L18 a87 head lots of good parts(even a good dash pad!) straight body! The cab was converted into a soft top though. It was nearly complete 1982 910 sedan MN47 head, autobox, non-removable caliper brakets in the rear, mostly complete. 1983 910 sedan MN47 head, no trans, non-removable caliper brackets in rear, I stripped, dash, pedals, grill assembly, trans, and a few other bits. 2 1985 Z31 non-turbo 2+2( for those after rear calipers of fuel pump assemblies) 4lug 1 1985 Z31 non-turbo coupe 4lug Hopefully this helps a few folks out 1 Quote Link to comment
