Archie Posted July 22, 2013 Report Share Posted July 22, 2013 Hello All, Installed new clutch and new slave cylinder. Clutch Master cyl was replaced less than a year ago. I have bled this system four or five times, starting at the Master, then the valve thingee on the firewall, ending at the slave cylinder. I have to pump the clutch pedal a few times at first to get enough pressure to shift into gear. After driving a bit and shifting through the gears, the pedal is nice and firm with perfect shifting.. Next day, same problem.. Could the master have failed????? I am quite sure I got all the air out of the system... THANKS Quote Link to comment
Tristin Posted July 22, 2013 Report Share Posted July 22, 2013 When you replaced the master did you bench bleed it first? Quote Link to comment
Archie Posted July 22, 2013 Author Report Share Posted July 22, 2013 Yes but it ran dry at one point, so I re-bled the master, on the vehicle, before bleeding the rest of the system... THX Quote Link to comment
