71 510 Stock Fuel Tank to EFI?
Esteep
I'm doing an sr20 swap and I want to use my stock fuel tank, my set up is a carburetor/lift pump to surge tank to main pump, but I don't have a return fitting for my return line. So my question, Could I remove the top breather hose from the tank and connect my return line there?  How much would it affect my fuel consumption? any one ever try it?
  • Replies 5
Are you going to use a 280zx replacement pump (external ) or some other ebay model, I use the feed at front R.side for return line 1/4 only  for a return at tank or drill and make 3/8 male a&n ,and  next  part is dangerous and pay a PROFESIONAL to WELD a bung in rear center of tank ,spare tire area, for a  90 deg.3/8  o ring seat fitting to #6 A&N.
I'm using external pumps, the carburetor/lift 4-7psi pump I picked up at a parts store and I got an MSD pump for my main pump around 40psi, I was trying to avoid welding anything to it but if I have to I will.
The sr needs only a 5/16 hose I was overkill with 3/8 sometimes.
Yeah I'm going to use 5/16 lines as both pumps, surge tank and filter  have 5/16 fittings.
