denis.drc Posted February 21, 2013 Report Share Posted February 21, 2013 ***********SOLD 2/23/13**********THANKS MIKE!*********** Moving the project into a different direction and need to make room for another power plant. The engine is an L16 with an A87 head & SU carbs. I rebuilt this engine less than a year ago and have driven less than 1,000 miles since the build.Everything works VERY well. No starting issues, no overheating, no leaks, no nonsense!It's still in my car. Anyone seriously interested is welcome to come by, start it, drive it, etc.. I'm in Sacramento.I'm including LITERALLY everything you need to drop this thing into your 510 and GO!I will post the cooling system up for sale soon too. Willing to work out a deal for everything. Look over my build thread and PM me.Motor build included:-new bearings-new piston rings-valve job-cylinder head has been machined .030 over for a compression bump.-all new gaskets-all new seals-valve adjustmentEngine also includes: -A87 Cylinder head-17lb lightened flywheel-new OE spec clutch & pressure plate-Dual SU carbs...recently tuned-Carb. throttle linkage assembly w/gas pedal-Manual choke assembly-Distributor, cables, coil etc..-Exhaust manifold & down-pipe-Engine wiring harness-Alternator w/external regulatorTransmission is Z 5-Speed.-No leaks-New shifter bushings-New shifter dust boot-New slave cylinder-Speedometer drive gear and cable (works perfectly!)-COMES WITH DRIVE-SHAFT to fit a 510 with R160 diff. ***********SOLD 2/23/13**********THANKS MIKE!*********** Asking $850 for motor/trans. combo. OBO (Please don't low-ball)OR$350 for trans.$550 for engine. ***********SOLD 2/23/13**********THANKS MIKE!*********** I am not interested in parting out the engine. Sorry..I don't want to sell the trans/driveshaft until the engine is gone. I want the buyer of the engine to be able to drive the car.Check out the build here:http://community.ratsun.net/topic/51284-72-510-sedan-build-denisdrc-lots-of-pics/Pics of engine: Link to comment
Apex944 Posted February 21, 2013 Report Share Posted February 21, 2013 If I hadn't just bought a ton of AR part's I would have picked this up for my 620.... Great deal, somebody local needs to pick this up ASAP. Link to comment
Hurley Posted February 21, 2013 Report Share Posted February 21, 2013 What head is on this engine? Link to comment
denis.drc Posted February 21, 2013 Author Report Share Posted February 21, 2013 What head is on this engine? Haven't checked the casting. Round port though.. I'll check tonight and post. Link to comment
denis.drc Posted February 21, 2013 Author Report Share Posted February 21, 2013 If I hadn't just bought a ton of AR part's I would have picked this up for my 620.... Great deal, somebody local needs to pick this up ASAP. Lol....damn democrats and their second amendment threats! :yawn: Link to comment
racerx Posted February 21, 2013 Report Share Posted February 21, 2013 head is probably 210. Link to comment
denis.drc Posted February 21, 2013 Author Report Share Posted February 21, 2013 head is probably 210. It's actually an 'A87' Just found a pic from when I had it off. Here it is: Link to comment
racerx Posted February 21, 2013 Report Share Posted February 21, 2013 that's a good head. Do you know if it's open or closed chamber? So it's an L16 with L18 head? Link to comment
racerx Posted February 21, 2013 Report Share Posted February 21, 2013 forgot to ask what's the compression on all fours? Link to comment
denis.drc Posted February 21, 2013 Author Report Share Posted February 21, 2013 that's a good head. Do you know if it's open or closed chamber? So it's an L16 with L18 head? Err..I don't remember and I can't find a pic of chambers... I'll err on the safe side and say open chamber...might be closed though.. :confused: forgot to ask what's the compression on all fours? Just after the first oil change @ 300 miles, it was ~160 across the board. Haven't checked it since, the motor has a total of ~800 miles now. Link to comment
racerx Posted February 21, 2013 Report Share Posted February 21, 2013 thanks...let me think about this.. Link to comment
denis.drc Posted February 21, 2013 Author Report Share Posted February 21, 2013 SALE PENDING! Link to comment
BigBopper805 Posted February 23, 2013 Report Share Posted February 23, 2013 is the tranny still 4 sale Link to comment
ohmrchristopher Posted February 23, 2013 Report Share Posted February 23, 2013 I kinda want this. Ill buy it but you'll have to wait till I roadtrip to Cali. Link to comment
denis.drc Posted February 23, 2013 Author Report Share Posted February 23, 2013 ***********SOLD 2/23/13**********THANKS MIKE!*********** Thanks for all your interest guys! Link to comment
