Bootdaddy Posted December 14, 2012 Report Share Posted December 14, 2012 Motors? Interior? Door panels? Seats? I have located a potential 1990 donor for 85kc thx Quote Link to comment
alabama_lowlife Posted December 14, 2012 Report Share Posted December 14, 2012 Motor? Yes with some work. Look around here for ka24e swaps. Interior? Not really. Maybe the dash if you make a bunch of brackets. It might be too wide anyway. Door panels? No. Seats? Yeah, with a little work. If its cheap enough and the motor is good, it could be worth buying. Quote Link to comment
izzo Posted December 14, 2012 Report Share Posted December 14, 2012 Check the front brake setup, too. Might have bigger brakes on it than the 720. You'd need the hubs, rotors, calipers etc. That motor should bolt up to the trans.. Might need to mod the motor mounts a little bit. Rip all the truck wiring out, along with intake. Use a 240sx intake and wiring, much less wires, easier to deal with. Really comes down to only 4 wires IIRC that you need to wire in. Youll need a few relays, and also a higher flow fuel pump (maybe take the one off the hardbody). Just all depends on how much time and effort (and $) you want to throw into the 720. It'd tear ass with a KA in there... Quote Link to comment
