72oakes240tree Posted October 18, 2012 Report Share Posted October 18, 2012 any one good at electrical any suggestions on the best way to set up my car i want two middies with tweeters up front low middies in the mid and some in the back as well as some subs. i guess im just asking for the way i should connect the harness and i know it depends on the head unit i use because i can run the wires. Quote Link to comment
Cahoon520 Posted October 18, 2012 Report Share Posted October 18, 2012 okay..... Quote Link to comment
Laecaon Posted October 18, 2012 Report Share Posted October 18, 2012 Well each speaker takes 2 wires. Um head units need battery and ignition power, and ground. Find those. Subs, well you need amps, and that is more in depth, but should take like 5 minutes to go find an article on crutchfield and learn all about it. Nothing to it but to do it. Quote Link to comment
72oakes240tree Posted October 18, 2012 Author Report Share Posted October 18, 2012 Nothing to it but to do it. well said thanks its a lot simpler then i made it seem in my head Quote Link to comment
