72oakes240tree Posted October 15, 2012 Report Share Posted October 15, 2012 I have a 72 240 I'm tring to get it low I know I need to section it but I want to know what parts I need and where I should get them also it would be really helpful if someone had pictures of there set up and the way they sectioned it. I'm tring to get adjustable ride height and not have to deal with to much fab work. Quote Link to comment
afbrian13 Posted October 16, 2012 Report Share Posted October 16, 2012 you should check out hybridz. Tons of suspension stuff like your looking for. I'm looking at doing a S13 suspension swap. check this out too: http://mckinneymotor... 260 280Z parts all the resto sites basically will get you an inch or two lower and thats it. Hope this helps a little. Brian Quote Link to comment
72oakes240tree Posted October 16, 2012 Author Report Share Posted October 16, 2012 I'm tring to go lower then that Quote Link to comment
M240Z Posted October 17, 2012 Report Share Posted October 17, 2012 http://forums.hybridz.org/index.php/topic/86623-crazyoctopus-1972-240z-build-up-long-first-post/ This is what I used as a reference to slam mine. Go through the build thread and it shows what to do. I'm on Stance coils, not Megans but it's pretty much the same thing. All you need is coils, rear coilover sleeves (have a machine shop make them,save $) and camber plates from zccjdm.com (about $20). My coilover sleeves for the front were metal, and the rear were aluminum which is why I had rears made. Not sure if all s13 coils or like this. You can also go miata coils or dc2 coils. I did s13 for beefier coils. Hope this helps, and pics are needed!!! Quote Link to comment
72oakes240tree Posted October 17, 2012 Author Report Share Posted October 17, 2012 if i had a machine shop make them what dimensions should i do and what metal? and could i do gc's Quote Link to comment
72oakes240tree Posted October 17, 2012 Author Report Share Posted October 17, 2012 you should check out hybridz. Tons of suspension stuff like your looking for. I'm looking at doing a S13 suspension swap. check this out too: http://mckinneymotor... 260 280Z parts all the resto sites basically will get you an inch or two lower and thats it. Hope this helps a little. Brian thanks for the info Quote Link to comment
72oakes240tree Posted October 17, 2012 Author Report Share Posted October 17, 2012 http://forums.hybrid...ong-first-post/ This is what I used as a reference to slam mine. Go through the build thread and it shows what to do. I'm on Stance coils, not Megans but it's pretty much the same thing. All you need is coils, rear coilover sleeves (have a machine shop make them,save $) and camber plates from zccjdm.com (about $20). My coilover sleeves for the front were metal, and the rear were aluminum which is why I had rears made. Not sure if all s13 coils or like this. You can also go miata coils or dc2 coils. I did s13 for beefier coils. Hope this helps, and pics are needed!!! do you have build specs or pics i want some ideas so i dont blow the bank or destroy my car Quote Link to comment
M240Z Posted October 18, 2012 Report Share Posted October 18, 2012 if i had a machine shop make them what dimensions should i do and what metal? and could i do gc's Yea you can go ground controls, you got to search though, I do not have much knowledge on those but I heard they're a little more work.Sunny's Z is super slammed on GC but doesn't have much suspension travel. It's all about how you section the struts with these. The dimensions depend on the coilover you use, just give them your coil so they can match the thread pitch. I'm not sure what type of metal I used but your going to be welding on them so get something thick so it won't warp. I got both of mine for $100 and the camber plates for about $20. I think mine are 7.5 inches long, again it depends on the coils though. do you have build specs or pics i want some ideas so i dont blow the bank or destroy my car I don't have any pics but the build thread I linked for you has plenty if you want to go with s13 coils. All you do is cut off your shocks and weld the new coilover tubes to the spindle. Then you cut out the stock top hats and weld the camber plates on. I also made gussets for the coilover sleeves to reinforce it. Quote Link to comment
72oakes240tree Posted October 18, 2012 Author Report Share Posted October 18, 2012 thanks and what should i have done to the rear ive seen tube kits but am not so sure about what to have the machien shop do for me if i ended up going s13 coils(witch i probably will for priece reasons) Quote Link to comment
M240Z Posted October 19, 2012 Report Share Posted October 19, 2012 It depends what you run, but all I did was get two steel tubes cut to 7.5 inches each and then I had a machine shop thread them out, you can go smaller though. Make sure you tell them you want the coilover to be able to bottom out in the strut tube because they have to bore it out a certain way in order to do that. Quote Link to comment
72oakes240tree Posted October 19, 2012 Author Report Share Posted October 19, 2012 Thanks really helpful I'm looking at some different custom shift knob have you seen any really neat ones out there Quote Link to comment
