dakotahchore Posted October 2, 2012 Report Share Posted October 2, 2012 Looking for a stock, working tach for my 510 wagon. I live in San Diego, California. Link to comment
deans510 Posted October 2, 2012 Report Share Posted October 2, 2012 I have an orange needle 4 wire tach. I'm not sure about its function so I can't vouch for that. I had one modernized by Randy York for less than $100 and it works great. I also have a local guy that modifies the 4 wire tach with a modern circuit board with 3 wires for $60. I think that Randy modifies the tach with a modern circuit board too. Based on what I have in mine, and the possible cost to modernize this one, I think $100 is a fair price. The back shows the original 2 white wires both with female bullet connectors, and original female and male spade connectors. Wiring for this is easy: Black goes to ground. Green goes to a switched positive (+) power source that only has power in the start and run positions. One white wire connects to the negative (-) side of the coil, and the other connects to the wire that was connected to the negative (-) side of the coil. (The white wires are hooked up so the tach is in series with the negative side of the coil.) An illumination harness can be made from a stock turn signal indicator harness, the bulb holders fit the tach, and the correct plug is on that harness for it to plug into your under-dash wiring harness. Pics at deans510@gmail.com Link to comment
