MantisX620 Posted September 7, 2012 Report Share Posted September 7, 2012 Im enjoying very much my new weber 32/26 carb. Sometimes though, the first start of the truck is extremely difficult. One thing ive noticed is the choke doesnt appear to be activating? Ive already manually engaged the choke butterflies, started it and set the fast idle speed. However, on a first start, it doesnt idle anywhere near the fast idle speed. In fact, it idles very low. After it warms up, it idles normally around 750rpm. I got it directly from redline so I assumed the choke was already set correctly. Im not sure what else to adjust. Ive got the mixture dialed in fairly well as it runs great and its smooth on the primary to secondary transition. Any ideas? Thanks MantisX Quote Link to comment
datzenmike Posted September 7, 2012 Report Share Posted September 7, 2012 When the motor is cold. Before starting, step on the gas several times. This will pump raw gas into the intake to richen the start up mixture and will set the choke. Take the air filter off when you do this and you should see the choke butterflys snap closed. If not, hold the gas peddle down and loosen the electric choke heater and turn the housing till the choke plates close. Quote Link to comment
MantisX620 Posted September 7, 2012 Author Report Share Posted September 7, 2012 Thanks! Will try this as soon as I get off work. MantisX Quote Link to comment
MantisX620 Posted September 8, 2012 Author Report Share Posted September 8, 2012 Thanks datzenmike!! It even starts easier now! Slowly this truck is becoming a real treat. Its almost graduated to daily driver status. Thanks MantisX Quote Link to comment
SulphurDave Posted September 9, 2012 Report Share Posted September 9, 2012 Good to hear. I'm in elementary school compared to daily driver graduation. Quote Link to comment
MantisX620 Posted September 9, 2012 Author Report Share Posted September 9, 2012 All I have to offer is to stick with it and thank the datsun gods for Ratsun.net! Quote Link to comment
blackwolf Posted October 19, 2012 Report Share Posted October 19, 2012 if you have a good idea of how the carb works you can set it up to were you step on the gas once and it will fire off easier than any fuel injected car ive got mine set like that even at 30 degrees it fires like its 100 Quote Link to comment
