WTB 510 Driver's Side Door Window Rubber Seal
  • Replies 4
The felt "run channel" that the glass window rides up & down in, is still available from Nissan. Used is always junk. Comes in a roll, you cut to length. You need to remove the door panel etc etc, diconnect the glass window from the window regulator, so you can push the glass out of the way a l'il, rip out the old felt channel, and install the new. I use black RTV silicon to glue the new channel in place, put it all back together, then leave your window UP for a few days, so the channel stays in place.
