HumanoidThe23rd Posted August 24, 2012 Report Share Posted August 24, 2012 WTB 510 Driver's Side Door Window Rubber Seal Thanks Bro(s) Link to comment
yenpit Posted August 25, 2012 Report Share Posted August 25, 2012 Which seal? Door jamb seal on the door itself, or the door glass felt seal, that the glass slides up & down in? Link to comment
HumanoidThe23rd Posted August 25, 2012 Author Report Share Posted August 25, 2012 the window seal. that the door slides up and down in. Link to comment
yenpit Posted August 26, 2012 Report Share Posted August 26, 2012 The felt "run channel" that the glass window rides up & down in, is still available from Nissan. Used is always junk. Comes in a roll, you cut to length. You need to remove the door panel etc etc, diconnect the glass window from the window regulator, so you can push the glass out of the way a l'il, rip out the old felt channel, and install the new. I use black RTV silicon to glue the new channel in place, put it all back together, then leave your window UP for a few days, so the channel stays in place. Link to comment
HumanoidThe23rd Posted August 28, 2012 Author Report Share Posted August 28, 2012 thank you very much for the advice! i will get on that asap. :D Link to comment
