*SOLD* For Sale - 1972 Datsun 510 SR20NA
1972 Datsun 510 -- $7,500 -- Not Trades
The car is an older build from PO, with the following details. The engine was pulled out of a Nissan Silvia with approximately 12k miles. I keep all of the fluids fresh, and it is definitely a blast to drive. Clean title/current registration. Please PM me with any questions. I am not willing to ship at this time. Local sale preferred.
Loc: NorCal
Car Info:
-- Engine
1993 Nissan Silvia S13
Nissan Stage 1 cams
Dual 44 Mikuni carburators on custom intake manifold - K&N air filters
Tanabe Limit AX (Jasma Spec.) SS header – not installed.
Removed SR ECU/electronics - modified SR distributor with Nissan A14 distributor EI. Stock coil
Fiero radiator w/ 12" electric pusher fan, thermo switch, and manual toggle switch
Nissan pickup electric fuel pump
Battery mounted in trunk w/ battery box
Custom 3” SS exhaust/SS Magnaflow muffler
5 spd trans. on modified stock crossmember
-- Front Suspension
Cut/flipped front crossmember
510 lower control arms grafted to 240sx control arms using 240sx spindles, hubs, brakes, rotors, and struts
JIC FLTZ 240sx coilovers 8kg springs
JIC camber plates
Techno Toy Tension Rods
-- Rear Suspension
Slotted rear crossmember
R180 (non-LSD)
Stock drum brakes w/ turned drums, replaced wheel cylinders, shoes
Long wheel studs w/ 10mm wheel spacer
Rear control arms are notched and plated to tuck wheel under stock fender
JIC FLTZ 240sx coilovers 6kg springs
Steel braided brake lines
-- Interior
Nissan Maxima electric seats - stock 510 seat belts
Mint dash pad, glove box w/ glove box compartment
Replaced headliner
Replaced carpet
Clean, stock, complete door panels with front/rear armrests and ashtray's.
Rear seat (a few common stitch/seam splits) - stock 510 seat belts
Replaced all weather seals/rubbers except for 1/4 windows - includes windshield, rear window, trunk, doors, side window trim rubbers, hood cowl.
Momo steering wheel
Stereo w/ pop-face controller and 6x9 rear deck speakers and stock 510 antenna
Stock speedo cluster (non Tach) w/ working stock idiot lights
Stock fuel gauge (working)
Heater/Vent/Fan controls all work
HID headlights
All electrical working, including open-door buzzer except for the following:
H4 High Beam headlights (believe the issue is with the turn/signal combo switch)
Wipers do not work – needs new wiper motor (not a problem, as I haven't driven the car in the rain)
-- Exterior
Body and paint is nice driver quality, and chassis is very clean.
All body trim, tail lights, grill, glass, in great condition.
New fuel tank hoses, including molded upper hose.
-- Wheels/Tires
Front: 16 x 7 RS-8 (225/50R16 Federal 535)
Rear: 16 x 8 RS-8 (225/50ZR16 Bridgestone Potenza Pole Position)
http://farm9.staticf..._c6edcaaf2a.jpg
http://farm9.staticf..._ce79261537.jpg
http://farm9.staticf..._cd1cb2d303.jpg
http://farm9.staticf..._5536423495.jpg
http://farm8.staticf..._76878114fa.jpg
http://farm9.staticf..._d55729bbfc.jpg
http://farm9.staticf..._028f0952a3.jpg
http://farm8.staticf..._6a5b42ec69.jpg
http://farm9.staticf..._dc5444f771.jpg
http://farm8.staticf..._cac074a81c.jpg
http://farm9.staticf..._be872020b1.jpg
http://farm9.staticf..._1456a5571b.jpg
http://farm8.staticf..._3af71f2fbf.jpg
  • Replies 6
