Nelsontr Posted May 31, 2012 Report Share Posted May 31, 2012 I am building up my emissions to go through DEQ and would like to get a replacement BPTV so i can get my EGR working again. I know a lot of people like to take this emissions stuff off, im just hoping someone held on to it. I have found a BPTV that is available from nissanpartszone (http://www.nissanpar...4741-u8400.html) but this is for a 310 but the same a14 engine, would this be a suitable replacement? Im pretty sure this is not an exact diagram of what i need but this shows what the BPTV should look like. Link to comment
ggzilla Posted May 31, 2012 Report Share Posted May 31, 2012 I have one, will you be at Canby? Link to comment
Nelsontr Posted May 31, 2012 Author Report Share Posted May 31, 2012 I will indeed be at Canby. You going for a day or the weekend? also, kind of a silly question, does it function? Link to comment
ggzilla Posted May 31, 2012 Report Share Posted May 31, 2012 I dunno if it functions, but it's free! I will check it out. Link to comment
Nelsontr Posted May 31, 2012 Author Report Share Posted May 31, 2012 oh, awesome! I am also in need of an a14 Valve Cover Breather Hose. Do you have one that is available or an idea of where to obtain one? Link to comment
ggzilla Posted May 31, 2012 Report Share Posted May 31, 2012 I bought my valve cover breather hose from Nissan. It's a special hose with anti-backfire inserts. Link to comment
Nelsontr Posted May 31, 2012 Author Report Share Posted May 31, 2012 Im thinking that this might be what i end up doing for the breather hose. http://www.nissanpar...mponentsIndex=6 Link to comment
ggzilla Posted May 31, 2012 Report Share Posted May 31, 2012 So you might use a factory 310 piece? Why not use the factory 210 piece? Link to comment
ggzilla Posted June 1, 2012 Report Share Posted June 1, 2012 Ah, mine is a 1981-1982 V.V.T. valve. It looks the same but apparently works differently. For a 1979-1980, there are two different B.P.T. valves: * FED * FED KFU (5-speed Coupe) They come in either Atsugi or Hitachi brand, which problably doesn't matter. For a 2-dr, part number 14741-24F10 should work. Link to comment
Nelsontr Posted June 1, 2012 Author Report Share Posted June 1, 2012 The Nissan Parts website i found (nissanpartszone) does not cover 210s but they do cover 310/310GX in the correct year... from what i have heard, the same car was titled as a b310 and a 210. would these parts do the same job on the a14 motor meant for a different body style? Link to comment
ggzilla Posted June 1, 2012 Report Share Posted June 1, 2012 1979-1982 "Datsun 210" is model B310. Look at your engine compartment ID plate to see what I mean. Link to comment
LeviGideon Posted June 1, 2012 Report Share Posted June 1, 2012 I've got one from an '82 with an a15, if you need it. Link to comment
ggzilla Posted June 2, 2012 Report Share Posted June 2, 2012 1982 doesn't use a B.P.T. valve. It uses a V.V.T. valve, which looks nearly the same. Link to comment
LeviGideon Posted June 2, 2012 Report Share Posted June 2, 2012 Oh, well that makes sense then. Link to comment
