sr20ve620 Posted May 23, 2012 Report Share Posted May 23, 2012 Is there any other option to madify a different booster to fit? I'm running a rop mount turbo set up on an Sr20 and the turbo hits the master cyl. I need to gain about 1/4",clearance. Can I go boosterless like 510s? Or is there another booster that someone has uses to get everything closer to the firewall? Quote Link to comment
ggzilla Posted May 23, 2012 Report Share Posted May 23, 2012 Yes, you can go boosterless. Just use a smaller diameter m/c so you can still stop with moderate effort. A 610 booster is smaller in diameter, that might be adaptable. Same unit was used on B210. Quote Link to comment
