brodster Posted May 21, 2012 Report Share Posted May 21, 2012 So I am about to start routing 3/8" line for my Z20E swap. My main issue is how to appropriately interface the rubber hose with the hardline. Two options as I see it: 1. Flare the hardline 2. Get a compression fitting. Any suggestions on a decently price tool? On the second option I found some prospective adapters. The first adapter is part of a carburetor designed kit. Apparently the compression fitting itself is rated to 100psi but the size of the barb concerns me for holding on the hose: http://www.jegs.com/i/JEGS-Performance-Products/555/159203/10002/-1?parentProductId= The other style adapted uses a compression fitting to AN. But then then you would have to buy an AN to barb adapter. Twice as many parts: http://www.jegs.com/i/Russell/799/639210/10002/-1 http://www.jegs.com/i/JEGS-Performance-Products/555/100845/10002/-1 Thanks Quote Link to comment
ggzilla Posted May 21, 2012 Report Share Posted May 21, 2012 Z20E uses medium fuel pressure, like the 280Z. so you can use those special stainless hose clamps like Nissan does. Quote Link to comment
