socaldatsun Posted April 10, 2012 Report Share Posted April 10, 2012 Hey guys I searched the threads but found two meesly post on this. I am verry paranoid about my truck being stolen and want to get a quick release for the steering wheel. I saw that one guy used this http://www.summitracing.com/parts/GRT-2001/ but is a hub adapter needed for this or it goes straight onto the steering colomb? or would the hub adapter and a NRG quick relese is better?I want something that is quick to take off and reliable to steer with. I am aware that this will bring the wheel a few inches closer. Quote Link to comment
Silky_Johnson Posted April 10, 2012 Report Share Posted April 10, 2012 I used to have one of these on my goon, but I took it off because it was old and developed too much play. It wouldn't have done that if the previous owner had it hooked up right, but it was too far gone. I have a garage now, so I'm not as worried about the car being stolen. From what I remember on mine, the quick release unit bolts up to a Grant hub adapter. It definitely won't go on just by itself. Quote Link to comment
southern620 Posted April 10, 2012 Report Share Posted April 10, 2012 Best bet would be figure out if NRG has any that will cross reference onto the steering shaft (like 350z or something) I've been trying to find one for my 620 with no luck yet. Quote Link to comment
socaldatsun Posted April 14, 2012 Author Report Share Posted April 14, 2012 actually I think I have a grant hub adapter on because I have an aftermarket steering wheel.because if you are going aftermarket you need a hub adapter right? Quote Link to comment
Grim13 Posted April 14, 2012 Report Share Posted April 14, 2012 Longacre Racing has a weld in quick release hub that may work Shorter one: http://www.longacreracing.com/catalog/item.asp?id=509&catid=15 Taller one: http://www.longacreracing.com/catalog/item.asp?id=504&catid=15 Quote Link to comment
