calistile Posted March 26, 2012 Report Share Posted March 26, 2012 Hi all - I have a S13 SR20DET Blacktop in my 72 510. I'm using a Freddy manifold. My question is, on the intake manifold side, there are coolant lines that I have capped off. 2 of them are supposed to go to the heater core (1 feed, 1 return). The 3rd line I capped, I think went to the intake manifold on the stock setup. Is it fine to just leave the 2 lines going to the heater core capped off individually? Or should I buy some line to sort of make U bend, to return coolant? If plugging is ok, are rubber caps with clamps good enough? Or should I consider having the capped off permanently (welded shut)? Thanks for any help you can lend. Quote Link to comment
Sinnful Posted March 26, 2012 Report Share Posted March 26, 2012 I would try to connect the two heater lines together if you are deleting the heater Quote Link to comment
AtlanticCoastDatsun Posted March 26, 2012 Report Share Posted March 26, 2012 I wouldnt plug anything, make sure you still have your coolant feed to your turbocharger Quote Link to comment
TheMission Posted March 26, 2012 Report Share Posted March 26, 2012 Do not cap anything. Run a U between the heater core tubes, from top to bottom and make sure to hook up your water lead to the turbo. Here's a pic to look at there... Just loop the top and bottom and keep the turbo little addition. There are still the leads to the IACV and such you need to keep on. Take a pic of the other lead you capped, as I'm pretty sure you want that connected as well. Quote Link to comment
AtlanticCoastDatsun Posted March 26, 2012 Report Share Posted March 26, 2012 why dont you just run the heater lines to your heater. If your engine ever gets a little warm you can use your heater as an added heat exchanger. The factory sr20 lines are bigger than your stock datsun lines so you will need to get some dayco brass couplings. Look in here for the information (part numbers) Mind you this is on a 620 but it is still the same concept. http://www.datsunminitruckin.com/sr20det-into-a-datsun-620_topic1632.html Quote Link to comment
calistile Posted March 26, 2012 Author Report Share Posted March 26, 2012 Sorry guys, I should have mentioned, I'm running the water line to the turbo via the water outlet that I had modded. The turbo is good. I was just wondering about the 2 core lines that went to the heater core. They're are capped off now, but it seems like a good idea to loop them together. Quote Link to comment
