510 misc parts- ebrake cable, transmission mount, etc
I have a manual pedal assembly 80.00
heater fascia or however its spelled 10.00
stock transmission mounts( i have 2 of them) 20.00 each
complete e brake set up from a 71 4 door, this is complete from handle on dash to the backing plates. every spring, washer, keeper, everything. the threads on everything is good, I unthreaded all of the nuts to disassemble everything. the casing has one bad spot in it, its the second picture 50.00
factory radiator shrouds, have 3 plastic ones and one metal one 20.00 each
factory stone shields that go below the front of the motor 30.00 each
I have other odds and ends, let me know if there is something you are looking for and I can look to see if I have it
parts are located in Battle Ground,WA
prices are WITHOUT shipping
  • Replies 9
  • 4 weeks later...
