Jasper Posted March 7, 2012 Report Share Posted March 7, 2012 My front right and rear left wheel cylinders were leaking, so I bought 4 new wheel cylinders to replace them all. I figured if 2 were leaking, the others were probably due. Changed the right front with no problems, other than having to pound the old one out with a BFH. I get the drivers side front one off with the same method, and... ...when I went to tighten down the nut that holds the wheel cylinder in place, the threaded rod thingy pulled out of the wheel cylinder. :rolleyes: Seems like the end of it broke off or something, although I'm not sure how. I had to use a giant cheater bar to get the nut off of the old wheel cylinder. I had only started to get the new nut snug with 1 arm before it broke. Currently trying a rigged fix. Put some JB weld in the hole, and pounded the threaded rod back into it with a hammer. I can't use the old one because I mushroomed the shit out of the threads. Has anyone had this happen before? Quote Link to comment
