DADZSUN Posted February 15, 2012 Report Share Posted February 15, 2012 So I'm in the process of installing a 280zx brake system into my 510. '81 front calipers and the 'newer' '83 rear calipers. Getting a bracket for the rear is a PITA, but that's another story. I've taken the front '81 calipers apart and cleaned/painted them. I'm about to reinstall and noticed that the sliding pins are different. Two are of the typical solid metal, and two have a plastic type of sheath. The bore on the caliper appears to be the same so I'm unsure of which order they go. Anybody know what the idea/purpose is to the 2-piece pin and does it go in front or rear of the rotor direction? Thanks! Fritz Quote Link to comment
NCLNDYM Posted February 15, 2012 Report Share Posted February 15, 2012 That's too funny. I just discovered the same thing today after I was done painting and cleaning the parts up. If I find anything out I'll let ya know. :cool: Quote Link to comment
NCLNDYM Posted February 16, 2012 Report Share Posted February 16, 2012 I've looked and can't find anything out as to why there are 2 different pins, any help out there Quote Link to comment
ggzilla Posted February 16, 2012 Report Share Posted February 16, 2012 They are called the Main pin and Sub-pin. Main pin goes in the top hole. Quote Link to comment
NCLNDYM Posted February 16, 2012 Report Share Posted February 16, 2012 Thanks, which one is the main pin, solid or the one with the rubber sleeve Quote Link to comment
ggzilla Posted February 16, 2012 Report Share Posted February 16, 2012 Main pin is the solid one. Coat both pins with a light layer of grease before installing so they slide easy, use the same grease that you use on the four sliding sufaces of the caliper. Quote Link to comment
NCLNDYM Posted February 17, 2012 Report Share Posted February 17, 2012 four surfaces, can you name them please...new to rebuilding the brakes. Quote Link to comment
ggzilla Posted February 17, 2012 Report Share Posted February 17, 2012 They don't have names, but the sliding surfaces are the places where the caliper touches the adapter bracket. It's just like drum brakes. Wherever the metal slides needs a very light coat of grease. I put a dab on then smear it with my thumb. Wipe off the excess. You don't want it getting on the brake pad/shoe material. Quote Link to comment
NCLNDYM Posted February 17, 2012 Report Share Posted February 17, 2012 I'm guessing the pins, the part where the boot slips onto the caliper. Not sure how the pads and the retaining clips work, they were off when i got them Quote Link to comment
NCLNDYM Posted February 17, 2012 Report Share Posted February 17, 2012 I'm guessing the pins, the part where the boot slips onto the caliper. Not sure how the pads and the retaining clips work, they were off when i got them Going to get my pads and if i can't figure it out, I'll be back. Thanks for the advice on the pins, was holding me up.:cool: Quote Link to comment
NCLNDYM Posted February 17, 2012 Report Share Posted February 17, 2012 Ok, so I've finally finished the rebuild of my brakes, etc...Anyone know where I can find some dust covers, I can't find them at any auto shop, OReillys, autozone, napa, pepboys, rockauto, where can I find some Quote Link to comment
ggzilla Posted February 17, 2012 Report Share Posted February 17, 2012 You mean grease caps? Get them at Nissan. For 1972 510, about $2 each: 40234-28500 CAP-HUB,FRONT WHEEL For 280ZX 40234-S0400 CAP-HUB,FRONT WHEEL Quote Link to comment
DADZSUN Posted February 22, 2012 Author Report Share Posted February 22, 2012 Good info, thanks ggzilla. Next question, typically the 280zx struts are swapped left <-> right on the 510. With the caliper mounted behind the strut in an OEM setup, the lower Sub-Pin 'receives' the rotor first followed by the Main-Pin in the top hole. However, when the strut's are reversed as in a 510 install, the caliper is now mounted in front of the strut and the rotor is now first 'received' from the top... Does that mean the Sub-Pin should be in the top hole? Makes sense what I'm trying to say? Thanks Fritz Quote Link to comment
