JCR Posted February 8, 2012 Report Share Posted February 8, 2012 1976 datsun 620 This was my 1st welder and my 1st time doing ANY kind of body work when I get to a point where I am not welding, grinding, repeat I will try using bondo I have decided that the next move to make everything easier is to pull the bed off Am I right in understanding that on the 76 the fuel tank is attached to the bed and not the frame rail?? Stay tuned in I am sure that there is going to be plenty of questions as I dig into the truck further and further Quote Link to comment
pharouh Posted February 8, 2012 Report Share Posted February 8, 2012 Yes the tank is attached to the bed on your truck. It was on the later 78s when they moved it to the frame. The bed bolts can be a bitch to get loose. there's been several posts about that. Do a search. why do you need to remove it? Oh yeah, your gas tank bolts will probably snap off . Take your time and soak them with PB blaster or Liquid Wrench. Quote Link to comment
JCR Posted February 8, 2012 Author Report Share Posted February 8, 2012 body work , rust , restore, clean there is a large hole in the front of the bed when i bought the truck and the guy i got it from was using the truck to haul mulch that has leaked through and is sitting all along the top of the frame got the 2 back bolts out with just a 1/2" driver the 2 on the drivers side are turning ....those top metal shims/nuts are spinning in the pockets and i am understanding the PITA that these are and you cant get a grinder or sawzall in the mount thinking of pulling the dremel out and cutting the nut in half or trying the chunk of metal in the pocket trick i saw someone mention on this forum doing a search now but if there are any tricks or tips ......I would appreciative the advice thanks ratsun brother'n Quote Link to comment
JCR Posted February 8, 2012 Author Report Share Posted February 8, 2012 got them off my secret : undo bolts untill the top spins jack up the bed so there is a small amount of space in between the frame and mount then sawzall blade in to the space and bob's your uncle did take me 4 or 5 hours to discover this tip and remove the bolts from start to finish but i did stop and play with the dogs run a call and eat lunch the gas tank and lights are still attached so that is for tomorrow getting there slowly Quote Link to comment
pharouh Posted February 9, 2012 Report Share Posted February 9, 2012 Good deal! I was the one who used the chunk of metal. I wanted to save the bolts. I got all but one. Had to use a sawzall. :rolleyes: Pictures? Quote Link to comment
JCR Posted February 9, 2012 Author Report Share Posted February 9, 2012 coming soon not really anything to see today tomarrow pulling the electrical , gas tanks , etc and going to remove the whole bed from the truck and then the start with the body work I was thinking of putting the bed upside down to work on it biggest problem is holes inthe bed heck the whole front is ate up with cancer have a doner bed for a patch pictures to follow Quote Link to comment
