JohnVander Posted January 28, 2012 Report Share Posted January 28, 2012 I was just wondering if there where any advantages to to going with B210 struts over a 1200 assembly, my setup is pretty shot and I'm looking at different options. Thanks John Quote Link to comment
ggzilla Posted January 28, 2012 Report Share Posted January 28, 2012 Pros: * Larger brakes (245 mm versus 212.5 mm) * Larger selection of strut insert cartridges (front shock absorbers) Cons: * Heavier * Spring heights are different * Same size brake calipers They are not a bolt-in replacement, but a strut swap. You'll need to do all the modifications of a swap: 1) cut and lower the spring perch 2) Use the B110 top hats 3) Change the ball joints 4) Change the tie-rod ends 1200 strut can fit larger brakes than B210. See bolt-on Brake Upgrade 1200 strut can be rebuilt (add new oil and new strut glands, such as the Koni rebuild kit) or fit 1200 strut inserts such as KYB gas-a-just or use VW inserts. See Strut Inserts Quote Link to comment
