north dakota Posted January 18, 2012 Report Share Posted January 18, 2012 I have a 72 510 sedan with full troy ermish suspension on 510 front struts, flares up front and looking to roll or somehow make flares for the rear....would 15x8 with 0 offset rims work or would i need to do furthermore modifications? Or maybe run a low pprofile tire on a 16x8 with 0 offset.....suggestions are welcome and info is appreciated.. Thanks, Ben Quote Link to comment
Xander_42 Posted January 18, 2012 Report Share Posted January 18, 2012 As far as your flare situation is concerned are you talking about a 2 or 4 door sedan? I know people can fit 8s on their 510s without flaring (w/ rolling), but I'm not sure how, because my 7s fill out the back quite a bit, and need to roll the fender already. Up front 15x8 +0s should fit great (w/ the flares), but you'll have more wiggle room if you're running 280zx struts. Quote Link to comment
Uber Deaf One Posted January 20, 2012 Report Share Posted January 20, 2012 I don't know how people can fit 15x8s in the rear without flares either... probably too much camber. In that case you're better off with a 7" wheel or flares, unless you only care about looks. Quote Link to comment
north dakota Posted January 22, 2012 Author Report Share Posted January 22, 2012 lookin at 16x7 with +4 offset.... http://www.rotawheels.com/wheels.asp?wheelid=34 thinkin of runnin 205/45/R16 http://www.tirerack.com/tires/tires.jsp?tireMake=Hoosier&tireModel=A6&partnum=045ZR6A6&vehicleSearch=false&fromCompare1=yes would this be a good size to run?...would spacers be needed with a +4 offset? Quote Link to comment
Xander_42 Posted January 22, 2012 Report Share Posted January 22, 2012 That sounds pretty good. Are you running 510 or 280zx struts? I doubt you'll need spacers. But with 510 struts you may have some wheel and tire sticking out past the fender. I just saw in GRM the other day that Rota is coming out with a replica of Watanabes, not the RBs which are a Panasport clone. I don't see it on their site, but if you're like me and like Wats better than Panasports, you might look into that. Quote Link to comment
north dakota Posted January 22, 2012 Author Report Share Posted January 22, 2012 i probably will look into it...but i am running 510 struts and coilovers in the front with fender flares. Quote Link to comment
Xander_42 Posted January 23, 2012 Report Share Posted January 23, 2012 Right, forgot about the flares. Yeah I bet those'll look great. Quote Link to comment
