datsun65 Posted January 1, 2012 Report Share Posted January 1, 2012 Need some help identifying what attaches to some of the loose wiring hanging throughout my engine bay. PHOTO #1 - On driver's side, near the windshield wiper motor. There is a white connector plug, and two additional wires (BLUE and the other BLACK) not connected to anything. What do these attach to? PHOTO #2 - On Driver's Side near the front corner of the car (near horn) . There is a relay with four connectors, but only 1 wire currently connected. What relay is this? Where is it suppose to be mounted in the engine bay? PHOTO #3 - On Driver's Side near front corner of the car. Three wires (B/Y, B/R, B). what does this connect to? PHOTO #4 - On Passenger Side below the fuse block , by the firewall. What relay is this. How is this supposed to mount? Photo #5 - On passenger side, below fuse block area. What relay is this? Photo #6 - Couple of wires near the front of the 510 engine bay. What wires should these attach to? Thanks, Dan Quote Link to comment
Laecaon Posted January 1, 2012 Report Share Posted January 1, 2012 Need some help identifying what attaches to some of the loose wiring hanging throughout my engine bay. Photo #1 I believe the plug is the carb switch and the wires are for the solenoid... I took this out of my harness. Photo #2 That is the emissions relay, mounts to driver's side lower radiator bolt. Photo #3 These connect to the above relay, are also connected to DUAL point dizzy's. I had a dual and went single, I took these wires out (well kept a Bl/R from dizzy to coil neg). Photo #4 Angle is bad for telling the relay, but I would bet on Headlight relay, mounts to back side of passenger strut tower, look for 2 holes vertically. Photo #5 Horn Relay, that is where photo 4 relay mounts. Photo #6 Yellow/Green? That is Low Brake Switch. Bl/Gr is Positive Side coil. Might need a further out pic to help identify further. 1 Quote Link to comment
