afbrian13 Posted December 30, 2011 Report Share Posted December 30, 2011 I've been looking at different camber plate options, and they aren't cheap. To me the weld in plate is way to easy to make, but then you'd still have to get a strut bearing-and they aren't cheap either. I saw these for sale: http://community.ratsun.net/topic/27002-moog-camber-plates/page__p__391909__hl__moog__fromsearch__1?do=findComment&comment=391909 old moog bolt in 510 camber plates-interesting, simple design. It looks like bolt in camber plates that could use the stock top hats and springs. Using these as an idea, I'm going to see if I could make a set for my Z. I know you'd have to trim the center hole of the tower to allow for adjustment(well-maybe), but they could still bolt in. Looking over all the options for lowering-chopping springs, coilover sleeves, etc- the biggest expense seems to be in camber plates and the bearing. How much angle has anyone here run on stuck tophats/strut bearings before they ripped? If you drop the car an inch or two by cutting springs how far off does it REALLY make your camber? I've looked at the question on other sites **cough**cough** and the answer is if its not dead on its wrong-not a functional yes it works but...like you get here. Has anyone found a decent ratsun cheap top strut bearing? I'm willing to chop some tubes down if it gets me the clearance to run bolt in instead of weld in camber plates. Any other ideas? Thanks, Brian Quote Link to comment
ggzilla Posted December 31, 2011 Report Share Posted December 31, 2011 Datsun Competition says you can notch the bolt holes, and pull the top hat inwards. But that was in the Datsun 1200 Competition Suspension booklet. Will the same work for a 510? Quote Link to comment
afbrian13 Posted December 31, 2011 Author Report Share Posted December 31, 2011 I'm playing with a 280, but its all the same idea. Thats another thing i was thinking, notch everything so it slides, but integrate a strut bar for extra strength at the top of the tower. I'd love to find some old school racing books, stuff from before you could just by everything. Thanks, Brian Quote Link to comment
