dscottdatsun Posted December 29, 2011 Report Share Posted December 29, 2011 Installing a 32/36 weber on my 79 620. The fuel lines (pump & return) are the factory hard lines. They are connected together where it feeds the carb. Do I block off the return line coming out of the top of the float bowl or seperate the the fuel lines to hook up the lines individually? Quote Link to comment
yello620 Posted December 29, 2011 Report Share Posted December 29, 2011 Leave the factory hard lines alone. The return line has a restrictor in it that works well. Hook the factory supply line to the fuel inlet(The one not shown in your pic) on the carb. The carb line at the top of the float bowl(shown in your picture) is a vapor line, no liquid fuel should be flowing through this one, it is above the float level. Most Weber's have that capped off from the factory, some dont. Quote Link to comment
dscottdatsun Posted January 1, 2012 Author Report Share Posted January 1, 2012 Got it in and running! :D Now to finish modding the stock air box to fit and this phase is done. Quote Link to comment
ZackTheImpaler Posted January 1, 2012 Report Share Posted January 1, 2012 Get a little breather for the valvecover! Quote Link to comment
