NEED AN L20B 6 bolt flywheel in SoCal
BDF
  • Replies 9
If you plan to use your original 200mm L16 pressure plate and clutch disc you will need a 200mm 6 bolt flywheel from any L20B equipped car. That would be a later 610 / 710 / S10 or S110(200sx) or A10 (HL510)
If the L20B wheel is from a truck it will be a 225mm and you will have to buy one. Oh, also if the larger 225mm you will not be able to use the L16 release bearing collar or housing. This is the thing that the release bearing is pressed onto. They are matched to the pressure plate and one for a 200mm will not work on a 225mm.
