Redd Posted April 12, 2007 Report Share Posted April 12, 2007 Taking the front cover off this little thing-a-ma-jig fell out of somewhere... When i pulled the cover off it fell off and landed on the lip of the oil pan...:confused: Pics are kinda large. Took with a cell phone and left them large to see the part http://i17.photobucket.com/albums/b74/poorsvtman/168895027205_3300.jpg http://i17.photobucket.com/albums/b74/poorsvtman/168894589061_3300.jpg Quote Link to comment
datsunaholic Posted April 12, 2007 Report Share Posted April 12, 2007 Valve lash pad. I've had one come off before- the rocker fell off and the lash pad (which is held on solely by the rocker) was loose amongst the valves. Boy did the engine backfire (dead cylinder) when that happened. Mine was caused by incorrect valve lash, but broken parts can also cause that to happen. In any case it results in a dead cylinder. Quote Link to comment
sjeff64 Posted April 13, 2007 Report Share Posted April 13, 2007 yep valve lash pad Quote Link to comment
Redd Posted April 13, 2007 Author Report Share Posted April 13, 2007 Thanks guys. guess it was a good thing i pulled the front cover off. if i hadnt i would have never realy knew Quote Link to comment
Redd Posted April 17, 2007 Author Report Share Posted April 17, 2007 finaly got to up to the shop to check things out after i got the front end torn apart... there are 2 of the valve lash pads off.. Found both of them... Another is turned a little bit and the corner of the part that sticks up on the sides is chipped off.. I think after i put them all back in and adjust them i should be good to go in that area. What you all think Quote Link to comment
Redd Posted April 19, 2007 Author Report Share Posted April 19, 2007 geez the valves were so out of adjustment it wasnt even funny.... Got them all adjusted now on sat its time to put everything back together and hopefully she runs Quote Link to comment
Bulletside Posted April 19, 2007 Report Share Posted April 19, 2007 Let us know if you gained a little power since you adjusted the valves and out the lash caps back in. I'd bet that you did. Quote Link to comment
Redd Posted April 19, 2007 Author Report Share Posted April 19, 2007 I wouldnt kno if it gained anything. got it not running guy i got it from didnt time it rite after a headgasket repair. i goin through everything to double check it all Quote Link to comment
