cashi123 Posted November 17, 2011 Report Share Posted November 17, 2011 Hello Ratsun guys I have a big problem that I need you help, well my situation is this I did the engine wire tuck on my 1974 Datsun 620 everything was going well but the only thing that I had to extend was all 4 headlight wires (low & high) using but connectors and I re wired averything back again, got all the components working good starter, alternator, distributor but my headlights are the only thing that is not working at this point ( won't turn on ) the rest of the lights ( interior and rear ) are working good . I verified fuse box and fuses and they all good check wires and they are properly connected .I'm running out of options here do you think that could be the lamp relay or light switch ??? O and also I did removed the 4 wires that goes to the lamp relay on the front next to the radiator that was connected with a ground wire, and I put it back according to the diagram that I have for the 620 but still not working PLEASE NEED HELP. Quote Link to comment
Eagle_Adam Posted November 17, 2011 Report Share Posted November 17, 2011 are you sure the diagram your using is for a 74? ive been told there are differences. I just ran into an issue with my 74 ( was never wired for a stock tack) link to 74 wiring diagram - http://www.davidcmurphy.com/olddat/data/dat620-1974.pdf heres where i got my info - olddatsuns.com good luck, im sure more members will chime in Quote Link to comment
cashi123 Posted November 17, 2011 Author Report Share Posted November 17, 2011 are you sure the diagram your using is for a 74? ive been told there are differences. I just ran into an issue with my 74 ( was never wired for a stock tack) link to 74 wiring diagram - http://www.davidcmur...dat620-1974.pdf heres where i got my info - olddatsuns.com good luck, im sure more members will chime in yes the diagram that I have is for the 1974 is the same one that you post here , and I still can't find the problem ??? Quote Link to comment
crackerjack69 Posted November 18, 2011 Report Share Posted November 18, 2011 You got a meter or testlight? Quote Link to comment
Slixon Posted November 19, 2011 Report Share Posted November 19, 2011 I've had a switch go out once and I've had fuse box fail me too. If you're sure of your wiring, check the switch. I actually have one for sale. Quote Link to comment
