sumith Posted November 10, 2011 Report Share Posted November 10, 2011 Hi Guys Today i completed Ever my first carburetor job,Cleaned Everything nicely and started the car it started at once, and kept for sometime without any problem , then i stopped it and again tried to start it it did not start but after few minutes it starts , and i kept it 1 hour without starting then i couldn't start it unless i put little fuel to the carb through air cleaner top, after that i could start it again and again within few minutes intervals only. it doesn't smoke at all and also spark plugs also were light brownish color after cleaning the car and start. And also notices when the engine is running the float bowl level is little above quarter,and after stop the engine it sits half way , have i mistaken any thing with float level of it ?it has got hard starting but ,i don't know to tune up it any more with idle air fuel mixture and timing on distributor, planning to take it to the mechanic on Saturday , any clue on what i have to do further to get it normal, specially with distributor settling and idle air mixture set up ? This is my B310 thanks regards sumith Quote Link to comment
Nicholas7620 Posted November 10, 2011 Report Share Posted November 10, 2011 Check your fuel pump, gas should squirt out forcefully, be careful you don't squirt gas all over engine, be prepared to catch gas with a glass. change fuel filter if you haven't done so. Quote Link to comment
