71pl510 Posted September 2, 2011 Report Share Posted September 2, 2011 I just got the s13 sr20det that will be going into my 510 2 door and I have a few questions 1st does any body have a link that I saw a few years back that lists the minimum parts required for a sr20det to run i.e. maf, ecu,etc. or in other words what all can I take off. 2nd does anybody know if any of the kits for the sr20det 240sx from ebay for example are of any use in a 510 I like the cast iron manafolds that are included most likely the radiator won't work (too tall) the intercooler should work and the pipes but not sure how good the turbos are seems like it might be a good way to get most of what I need in one shot then maby replace the turbo down the road when more funds are avalable. example: http://cgi.ebay.com/ebaymotors/NISSAN-240SX-S13-S14-SR20DET-ENGINE-TURBO-KIT-32-FMIC-/150656535273?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3A240SX&hash=item2313d44ae9 yep I think I have read nearly or all the build threads Thanks Quote Link to comment
sycloned916 Posted September 2, 2011 Report Share Posted September 2, 2011 Something like that could work,just would depend on what will work for your set-up. I think every project is different on how you want it to all fit and work. A kit like that might come with everything you need but will it fit were you need it. I pieced all my parts together because on how tight everything was. It's a big puzzle. Wiring it is easy afew wires and 3 relays and it will run. Yep you'll need the MAF,ECU,O2,ignitor chip and harness. Other than that is real easy,engine will just about drop right in the 510. Have fun. Quote Link to comment
71pl510 Posted September 2, 2011 Author Report Share Posted September 2, 2011 yep I figured I would need to mod the manafold some and this and that, I was hoping one of these kits would have enough of the pieces to jig saw it togeather Quote Link to comment
