BoostinBen Posted August 17, 2011 Report Share Posted August 17, 2011 I just had the passenger door latch go bad in my 510 .. looking for a replacement. shoot me a PM if you have one. Link to comment
ariascarlos1990 Posted August 17, 2011 Report Share Posted August 17, 2011 Are you sure its not just the spring? 1 Link to comment
BoostinBen Posted August 17, 2011 Author Report Share Posted August 17, 2011 Are you sure its not just the spring? I think it is the spring ... I havent taken it apart though.. can the spring be reset into position or replaced? Link to comment
ariascarlos1990 Posted August 17, 2011 Report Share Posted August 17, 2011 I knew I should of taken pictures when I did mine! Take it out and play with it you'll figure out what needs to be done. The spring it pressed in so it will be a bitch to replace. I would do like I did and add a spring to the side of the mechanism to keep the latching piece down. Link to comment
Chris#51EPGraham Posted August 18, 2011 Report Share Posted August 18, 2011 I've got one from a 73 2 door if you need a replacement. Link to comment
