71hls30 Posted August 5, 2011 Report Share Posted August 5, 2011 Hi thanks for reading. I am trying to figure if i can re-route the brake lines from master cylinder to proportioning valve. ( instead of to the bottom of valve, i want to run directly into the top by the brake switch.) I would like to attach a pic. But i don't think i can. Will running the lines to the top make the brake lights stay on.. any advice would be helpful. Quote Link to comment
ggzilla Posted August 5, 2011 Report Share Posted August 5, 2011 The brake light is not supposed to stay on, it is supposed to stay off. The 240Z comes with "Brake switch", and not a proportioning valve. Most cars have no proportioning valve, instead the proportioning is engineered into the relative sizes of front and rear brakes. The brake switch has line splitters intergrated. Here is what it looks like inside: Quote Link to comment
71hls30 Posted August 5, 2011 Author Report Share Posted August 5, 2011 Wow, you are awesome!! Thank you very much for quick and informative response.. Quote Link to comment
