fiveNdime Posted March 10, 2008 Report Share Posted March 10, 2008 I have a 95 KA in my dime. I have been doing some playing around trying to figure out why it doesnt have the power of others I have driven. Simpy put I pulled my O2 sensor off today and ran it. What a difference it made. It ran much better and snappier. Could anyone tell me why it would do this????? Quote Link to comment
ggzilla Posted March 10, 2008 Report Share Posted March 10, 2008 Check out the engine codes. Something is wrong. When you disconnect a sensor, then the ECU calculates the value. Probably the O2 sensor is putting out a bad value. Do you have the 02 sensor in the same place as stock? Even a few inches further back will give a bad reading. Quote Link to comment
fiveNdime Posted March 10, 2008 Author Report Share Posted March 10, 2008 Codes are correct......5 slow then 5 fast flashes of the LED on the ECU. I am using a frontier header and I just put the sensor in the bung they welded up. The O2 has about 25 hours on it so its pretty new. Still dont know. Maybe I have a problem somewhere else? Quote Link to comment
