hoop-d_210 Posted July 14, 2011 Report Share Posted July 14, 2011 Hey guys im new here and i got a few questions. i have a 80 210 with a A15 automatic and im picking up a B210 that i believe is a 75 or 76 with a A14 and a 4 speed. Its been sitting for something like 15 years but im trying to find a little bit of information on putting the 4 speed into my car. Is it a pretty straight forward swap or is there something i need to know about ahead of time? Any help would be appreciated thanks ahead of time Quote Link to comment
ggzilla Posted July 14, 2011 Report Share Posted July 14, 2011 Swapping a B210 4-speed into the B310 is fairly straightforward. Use the B210 driveshaft. When converting an automatic car to manual, you will need * manual pedals from another B310 (1979-1982 Datsun 210), as they are different from the B210. * Bypass the starter inhibitor wiring. This mean adding a jumper wire to the wiring harness that goes down to the automatic. * Wiring for the reverse lights, etc is different for the two cars (uses different connectors) Quote Link to comment
hoop-d_210 Posted July 14, 2011 Author Report Share Posted July 14, 2011 ok cool thanks for the info. Guess i need to find a set of pedals i was really hoping i could use the pedals out of the other car but i will start doing some looking Quote Link to comment
ggzilla Posted July 14, 2011 Report Share Posted July 14, 2011 Well they might work ... people have asked before, but no one has ever said. But I know the ones from the 210s work. Most everything about the bodies and interiors are different. Quote Link to comment
hoop-d_210 Posted July 14, 2011 Author Report Share Posted July 14, 2011 ok thanks again once i get the car to the house i will do some looking and see how much different they are and i will post up on here whatever i find out Quote Link to comment
hoop-d_210 Posted July 15, 2011 Author Report Share Posted July 15, 2011 Another quick question if anyone happens to know the rear diff ratio on a 80 210 auto and a 75 b210 4 speed? Quote Link to comment
ggzilla Posted July 15, 2011 Report Share Posted July 15, 2011 all B210 diff ratio is 3.889 1980 B310 with auto could be several different ratios 3.700, 3.889 or 3.454, depending on the engine and whether it is a U, V, or C car. The service manual lists ratios but they don't match the real world. It says on the underhood plate (HB35, HB37, HB39). Quote Link to comment
