dat521gatherer Posted July 8, 2011 Report Share Posted July 8, 2011 I'm looking for these parts for my 75 b210 or original part numbers. fusebox, used is fine no cover needed hood bumpers 2 of them, used is fine. The ones on ebay aren't correct. Horns needed really bad. 1 high 1 low, used is fine coil boot I'll pay with paypal/cash/money order. I got all of this stuff, thank you and please scroll down for other parts I need. Link to comment
dat521gatherer Posted July 8, 2011 Author Report Share Posted July 8, 2011 I'm looking for these parts for my 75 b210 or original part numbers. fusebox, used is fine no cover needed hood bumpers 2 of them, used is fine. The ones on ebay aren't correct. Horns needed really bad. 1 high 1 low, used is fine coil boot fm radio I'll pay with paypal/cash/money order. mod please move this to parts wanted. :wacko: Link to comment
ericsb210 Posted July 8, 2011 Report Share Posted July 8, 2011 I have the parts you need, all off of a 75 B210 HB. Shoot me a PM. Link to comment
dat521gatherer Posted July 14, 2011 Author Report Share Posted July 14, 2011 Thanks for the parts Eric and Redbanner!! New list of parts wanted. Rubber muffler hanger and ubolt. cant find correct ubolt at the parts store.--Got Auto shift knob-minty Coat hangers--Got Locking fuel door Trunk rug Battery hold down Tach Clock Thermostat housing non smog More important stuff Left lower door hinge. Grey left horn button with springs and screw. Long heater hose. Factory only I have a chopped up ghetto mess! nla from nissan. Auto trans speedo gear. any idea at least on the part number? Tail pipe. Might go to a muffler shop but they usually wanna replace the whole system. Battery hold down, I may go after market on this. Link to comment
RedBanner Posted July 17, 2011 Report Share Posted July 17, 2011 I found two ways to deal with the u-bolts, drill the perch out for the off the shelf ones, or have some made I went to a four wheel drive shop and got 4 for 50 bucks. I bet you could find em cheaper u was in a hurry, good luck Link to comment
dat521gatherer Posted January 26, 2012 Author Report Share Posted January 26, 2012 I currently have the dash out and before I put it back in I need the defrost vents that go to the windshield and a auto trans speedo cable. Got them thanks. Link to comment
ggzilla Posted January 26, 2012 Report Share Posted January 26, 2012 Speedometer cable is same as 5-speed cable. About $15 at Oreilly Auto You can fit both cable and defrost tubes after the dash is reinstalled. Link to comment
ericsb210 Posted January 26, 2012 Report Share Posted January 26, 2012 I believe I have a set of defrost vents. You are refering to the ones that bolt onto the body of which the defrost tubes hook up to, correct. Link to comment
dat521gatherer Posted January 26, 2012 Author Report Share Posted January 26, 2012 I believe I have a set of defrost vents. You are refering to the ones that bolt onto the body of which the defrost tubes hook up to, correct. These ones. Link to comment
ericsb210 Posted January 26, 2012 Report Share Posted January 26, 2012 I beleive I have a set of those, give me a day to look for them. I will get back to you. Link to comment
ericsb210 Posted January 27, 2012 Report Share Posted January 27, 2012 So far I found the rubber vibration dampers that go on top corners of defroster vents (between defroster vent and dash) they are the crescent moon shaped items. Do you need those also? Link to comment
dat521gatherer Posted January 28, 2012 Author Report Share Posted January 28, 2012 I haven't taken them out of the car yet as it's still being driven. I didn't see anything like those when I looked under there so I probably need them. Link to comment
ggzilla Posted January 28, 2012 Report Share Posted January 28, 2012 That's what Duct tape is for -- for sealing ducts. Link to comment
dat521gatherer Posted April 29, 2012 Author Report Share Posted April 29, 2012 Thanks for the parts Eric and Redbanner!! New list of parts wanted. Rubber muffler hanger and ubolt. cant find correct ubolt at the parts store.--Got Auto shift knob-minty Coat hangers--Got Locking fuel door Trunk rug Battery hold down Tach Clock Thermostat housing non smog More important stuff Left lower door hinge. Grey left horn button with springs and screw. Long heater hose. Factory only I have a chopped up ghetto mess! nla from nissan. Auto trans speedo gear. any idea at least on the part number? Tail pipe. Might go to a muffler shop but they usually wanna replace the whole system. Battery hold down, I may go after market on this. Bump Link to comment
