BenJammin Posted May 17, 2011 Report Share Posted May 17, 2011 I had to cut one of mine out to get the lower control arm off (was ruined from banging on it anyway after I gave up with the brass drift ). If you have it, you probably know what it looks like, but I'll get a pic up later. One end is the toothed head that fits into the stabilizer/anchor piece for the torsion bar [spring]. Or if anyone knows an alternative? Link to comment
yello620 Posted May 17, 2011 Report Share Posted May 17, 2011 I had to cut one of mine out to get the lower control arm off (was ruined from banging on it anyway after I gave up with the brass drift ). If you have it, you probably know what it looks like, but I'll get a pic up later. One end is the toothed head that fits into the stabilizer/anchor piece for the torsion bar. Or if anyone knows an alternative? Assume this is for you 73 620? The 72-77 trucks should be the same lenght, while the the 78/79 trucks have a longer bolt. I might have an early one, maybe. Link to comment
BenJammin Posted May 17, 2011 Author Report Share Posted May 17, 2011 Thanks, yeah I need the early one (kingpin suspension), let me know when you find out what you have and what you want for it. Link to comment
