MINItech760 Posted April 10, 2011 Report Share Posted April 10, 2011 hey everybody, complete datsun noob here bought a 71 510 goon, and im swapping in a '93 ka24de does anyone know how much i can actually remove from the engine, emission wise, and it still function correctly mechanically and electronically?? i.e. egr, egr control valves, vacuum lines. Quote Link to comment
KA620KC Posted April 10, 2011 Report Share Posted April 10, 2011 I just swapped in 92 KA into my 77 620 and removed just about all the emmissions from it. EGR is completely gone and I only kept the bare essential Vacuum lines like for the fuel pressure regulator. Don't ask me about wiring though!! I'm still having some issues with mine! LOL Quote Link to comment
MINItech760 Posted April 10, 2011 Author Report Share Posted April 10, 2011 So you took off everything except temp/pressure sensors and injector/ignition components? Quote Link to comment
MINItech760 Posted April 10, 2011 Author Report Share Posted April 10, 2011 did you just plug all the vacuum lines to the throttle body and manifold? or did you leave those ones connected? and did you use the 240 trans or original trans if you used the 240 one, did you use any of the harness for it? other than the crank sensor? Quote Link to comment
