rbastedo Posted March 29, 2011 Report Share Posted March 29, 2011 Maybe 6 weeks ago I put a 5 speed dogleg in behind my A15 motor. At that time I put in a new clutch pressure plate and disc. The problem is I get a slipping going on mainly 3rd, 4th & 5th gear above about 2500 RPM. It will race up in rpm with no noticeable power increase then "catch" and the rpm drops and it has power. Do you think I'm somehow getting oil on the disc or maybe something else? Clutch is all adjusted perfectly and things generally working well other than this. Quote Link to comment
