WTB R-180 4.62 & 4.875 DIFF Open or LSD
  • Replies 10
  • 1 month later...
The early 4x4 720s only used a 4.375 diffs. The later (with Z24 motors) used 4.11s. There were no diesel 4x4s made.
The Pathfinder wih Z24i motor and later Hardbody after '96? with KA motor used a 4.625 R-180 front diff but it had a longer axle stub on the driver's side. I'm pretty sure it will unbolt and a regular stub axle bolts on.
The majority of D-21 and WD-21s used a R-200 front diff with the VG motor.
I think some of the info I was getting applied to either Australian or European 720's and may not apply to their US counterparts. I'd heard that the the early 79-80 720 4x4's had the 4.62's. And that the early 720 diesel 4x4's (Aussie) had the 4.88 ratio R-180's.... My head is going to explode...
In either case, thanks for helping clear things up Mike.
  • 3 weeks later...
Your right. 8/79-6/80 720 4x4 longbeds had 4.625 front diffs, try to find one. King cab 4x4's with 4.375's are easily sourced in Pick-a-Part, at least in AZ.
Roger
