kaoss Posted January 17, 2011 Report Share Posted January 17, 2011 Just my luck the rear end I pulled from the junk yard has a bent axle. The passenger side is bent, I'm not sure if the two sides are interchangeable. I already tried the one from my 620, it's too long. Let me know what you have and how much you want for it. Any other ideas or advice is appreciated. Link to comment
datzenmike Posted January 17, 2011 Report Share Posted January 17, 2011 The 620 is wider so the axle is longer than the 521. Axles should swap side to side between 521s only, and 620 only, but you would also need to swap the backing plate with the brake stuff on it. Link to comment
kaoss Posted January 17, 2011 Author Report Share Posted January 17, 2011 Will a 520 axle work? Link to comment
datzenmike Posted January 18, 2011 Report Share Posted January 18, 2011 Yes I believe so. The part #s are the same. Link to comment
kaoss Posted January 21, 2011 Author Report Share Posted January 21, 2011 I'm having no luck finding an axle. I talked to a local fab shop and on his advice I'm going to take the chop saw after my 620's axle. Good thing I have parts truck in case this goes badly. Link to comment
