PEZi720 Posted January 11, 2011 Report Share Posted January 11, 2011 So, my build project will be getting all new wiring coming soon. All the stock crap is coming out and will be replaced with new wires only for the stuff I need to work. Before I can do this though, I need to know what the hell the stock little computer thing does and if I can remove it. I have a weber carb, so the wiring that went to the stock carb is already gone. No power windows or any of that crap. It's all pretty simple for what I need to work... simple circuits. But I need to make sure there are no controls or something that won't allow the truck to run properly without the stock computer thing. I also need to know a little info on the wiring of the ignition for the z24 dual plug system if anyone knows how it works or if its even any different. From the battery, I will have a master disconnect switch. Besides that, the only wiring i will have is: Ignition system Tachometer temp guage oil pressure guage fuel pump headlights taillights blinkers TIA guys! Quote Link to comment
Wide14u Posted January 11, 2011 Report Share Posted January 11, 2011 i dont think you need a ecu with z24 Quote Link to comment
