datsunfish Posted January 26, 2008 Report Share Posted January 26, 2008 So I figured I should post up some pics of my progression so nobody thinks I half assed things.My 510 had very minimal rust.Cancer in the rear quarter panels and a tiny bit at the gas pedal.It went from bb size to pea size really quick while driving it in the rain so I got in there with a wire wheel and some por 15 to put it to a halt.I have to cut out the section on the floor and clean out all the rust and dirt that fell into the body pan channel and weld on a new piece.My pedal got cracked up a bit taking it out since the screws were rusted in place but thats a small sacrifice to prevent further cancer. I dont have any before pics of the cancer on the passenger side rear cancer but it was pretty bad.About 4 inches of dirt stuffed in there so I cleaned her out and welded on a new chunk of metal.Very difficult to weld on the stock panel since it is paper thin and pocked with rust but I figured it out. Tons of weld was added which required tons of grinding.My arm is sore.this shows me where I need to hit it with the welder on a few small holes.Better to have a thin layer of body filler on top of solid metal than glass up a big hole. Quote Link to comment
DISLEXICDIME Posted January 26, 2008 Report Share Posted January 26, 2008 good job ! Quote Link to comment
DISLEXICDIME Posted January 27, 2008 Report Share Posted January 27, 2008 good job ! Quote Link to comment
datsunfish Posted January 27, 2008 Author Report Share Posted January 27, 2008 with primer Quote Link to comment
clean71 Posted January 29, 2008 Report Share Posted January 29, 2008 did you get rid of the hole on the driverside qtr panel?car is coming along nicely though. oh also have you used the radiator yet? Quote Link to comment
datsunfish Posted January 29, 2008 Author Report Share Posted January 29, 2008 Its still as pictured on the drivers side.I think I can zip up those holes rather than cut in a new panel.I havnt used the radiator yet since it has no tranny ports.I have an aux cooler but want to be sure I dial it in right first and the f'ed up one in there is holding nicely during the cold season.I am considering a lz24 project but if not I at least have a L20b but I kinda want that in my 521.So long as it runs for now I can do the body stuff and have that out of the way later. Quote Link to comment
