Rod S Posted December 2, 2010 Report Share Posted December 2, 2010 i am tring to put new seals in the tail shaft housing . i am geeting oil from the shifter and i cant remove the pin from the shift fork can you help Quote Link to comment
defdes Posted December 2, 2010 Report Share Posted December 2, 2010 i am tring to put new seals in the tail shaft housing . i am geeting oil from the shifter and i cant remove the pin from the shift fork can you help There's just a C clip on one side, if it wont slide out soak it in wd40 and take a C clamp with a small nut or something of a smaller diameter on the push side and a slightly bigger diameter socket on the other and push it out. Quote Link to comment
