ZX brake size? (OICS!!!)
Stupid_fast
I searched.
Basically what I found is some 13" wheels fit ZX bakes, some don't and some fit if you grind the calipers a little.
So the info I need is how much the ZX calipers stick out from the rotor.
The 13" enkei 80's I have have an inner diameter of 12 inches(maybe 12.5? I did crappy measuring) at the rim, its in a cone shape in so the further in the smaller the measurement gets.
They are pushed out like 25mm by the wheel adapters.
The distance between the 9" rotor and the wheel is 2 inches at the point its mounted.
With the stock 510 brakes.
So, can anyone get the measurement of the ZX brakes, or any other optional upgrades that will fit? Thanks!
I'm going to run the stock ones for a while, but for autoX and general street I will want better brakes.
  • Replies 3
Frank runs ZX brakes with slightly ground calipers inside 13" wheels. They look so snug in there its ridiculous. Measurements will be really close anyway so the only way to be sure is to test fit them and start grinding. I know that costs money though...
Thanks for the reply, in that case I can just grab one from a junk yard for cheap and see how it fits.
