510Finn Posted November 1, 2010 Report Share Posted November 1, 2010 On my stock '72 Wagon, was driving it, then I heard a pop sound almost like a tire stem breaking off, and hissing, then the car won't idle and will only drive when there's excessive gas being pumped in by the accelerator. Since it was at night, I had to tow the car home. So now i'm finally looking at this thing and couldn't find the problem, but I suspected a massive vacuum leak, because I hear it hissing loudly and the car won't idle. So I took the Hitachi carb off, then looking at the side near the vacuum secondary I notice this huge hole. You can see down into the carb from this hole. Is there supposed to be a plug or cap here? Did it pop a cap? Does anyone know what I can use to plug this? Brass plug? small aluminum cap? Quote Link to comment
Nicholas7620 Posted November 18, 2010 Report Share Posted November 18, 2010 Since you don't have to worry about smogging, replace that Hitachi with a Weber. It look like you blew out a vacuum tube. The hose should be laying in the area. A newly rebuilt Hitachi for 1972 might be available, but then you would still have a 40 year old Hitachi. Probably better to get a newly born carb. Just saying ;) ! Quote Link to comment
