Dimerforlife13 Posted October 22, 2010 Report Share Posted October 22, 2010 Let me know if you have one in good shape. Mine is toast, and my repair didn't work out too great. Thanks -Brett Link to comment
Pacific coast Datsun Posted October 22, 2010 Report Share Posted October 22, 2010 These can still be bought new at O reileys / Kragen....... http://www.oreillyauto.com/site/c/detail/BAR0/1013458.oap?year=1974&make=Nissan&model=620%2BPickup&vi=1210105&keyword=center+support+bearing Link to comment
650savag Posted October 22, 2010 Report Share Posted October 22, 2010 You can order the "insulator" only which includes the rubber bushing from Rockauto for about $17. I pulled my shaft out and used a grinder to "carefully" remove the old insulator from the bearing and then pressed the new insulator on the old bearing. The bearings are usually still good. It's just the rubber insulators that wear out. Just be carefull when grinding the old insulator off and don't grind down into the bearing. It's a cheap and easy fix. Just go to Rockauto parts onbline and look in The "Nissan" listings for a 620 or 1980 720 pickup and look under "driveline" and it will list the center support bearings along with the insulators. BECK/ARNLEY Part # 1013460 Includes Rubber Bushing Link to comment
Dimerforlife13 Posted October 22, 2010 Author Report Share Posted October 22, 2010 Thanks a lot guys, I thought the were no longer available. This post can be deleted. -Brett Link to comment
